Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 90
Thread: Ant Weight Circuit Help
  1. #21
    The new V3 version of the NanoTwo is meant to be out in a week or so I think...
    As I say, come bring it to the social, might get a good idea of just what went wrong.
    BW: Shu!, The Honey Badger
  2. #22
    Bad Wolf
    Guest
    Yeah I can’t wait, I think I’ll buy a couple to get me started on a couple of Ants! And yeah I’ll defo bring it with me, would be great to have somebody who knows what’s what looking at it!
    Bad Wolf
  3. #23
    I am a bit perplexed about your esc. Do you have access to a multi meter? If you do check to see if you can see the winding resistance on your motor terminals. It should be around 10-20 ohms. If its around 1ohm or less then you have shorted the motor.
    Regardless though, definitely contact the supplier for your esc and see if they can replace it for you. If that falls through then you could probably go for a Dasmikro. you do have to solder everything together unfortunately. link is here:
    https://www.banggood.com/2S6A-Micro-...r_warehouse=CN
    Make sure you change the shipping to priority direct mail else it will be give a months romantic cruise for 1. Changing the shipping is a bit hidden away but its there on that page.
    If you are a bit tired of soldering you could probably try these by vex. They are individual motor drivers and are a bit heavy at 10g each. Ive seen them used in beetle weight with no apparent drawbacks and should be suitable for ants.... unless someone can point out something glaringly obvious to me.
    https://www.vexrobotics.com/276-2193.html
  4. #24
    Bad Wolf
    Guest
    Quote Originally Posted by Scottie View Post
    I actully habe a Dasmikro! I’ve just never taken it out of the bag it came in, I’ll admit when it first came I looked at it and was like ummm no! Hahaha I think it was because it didn’t come with any instructions so I had no idea where anything really wen, but now I’ve done a bit of soldering I might be abit more confident at giving it a go now! I’ll give it a try later this afternoon! Cheers mate!
    Bad Wolf
  5. #25
    Bad Wolf
    Guest
    So with the things from Vex, I’d need two? One for each motor? And they JR plug into the Lemon?
    Bad Wolf
  6. #26
    Yeah, you'd plug them into the Lemon and then have the transmitter do the mixing to achieve forward motion.
  7. #27
    Bad Wolf
    Guest
    Well that seems a lot easier? :/ is it just a weight issue that is the draw back?
    Bad Wolf
  8. #28
    Well there will be no harm in trying the dasmikro if you have it. Admittedly the only wiring information is on the web page where you buy it. It is a bit vague as ive known some people to try and connect VCC to VCC servo at some point in their system. Make sure not to do that If you are unsure draw your a wiring diagram and post it here and people here will give you a verdict on it.
    And yes that is correct about the vex. Obviously you will have to solder motors to it as well.
  9. #29
    Bad Wolf
    Guest
    yeah I’ll post it on here before I solder the dasmikro, sounds like a plan, cheers!
    And okay cool, I’ll order a couple of them Vex things today! Give them a go as well!
    Bad Wolf
  10. #30
    Bad Wolf
    Guest
    So is this the right lay out? I’ve got red and black going to the motors, two JR cables and then a power cable
    https://imgur.com/gallery/LxZ
    this is the curcuit abit closer to see the lads hopefully!
    https://imgur.com/gallery/ucag1
    And im just wondering what these yellow things are? Do I need them?
    https://imgur.com/gallery/FG4Dd
    Bad Wolf
