Results 1 to 10 of 90
Thread: Ant Weight Circuit Help
Hybrid View
    Well there will be no harm in trying the dasmikro if you have it. Admittedly the only wiring information is on the web page where you buy it. It is a bit vague as ive known some people to try and connect VCC to VCC servo at some point in their system. Make sure not to do that If you are unsure draw your a wiring diagram and post it here and people here will give you a verdict on it.
    So with the things from Vex, I’d need two? One for each motor? And they JR plug into the Lemon?
    And yes that is correct about the vex. Obviously you will have to solder motors to it as well.
    Bad Wolf
    Guest
    Quote Originally Posted by Scottie View Post
    yeah I’ll post it on here before I solder the dasmikro, sounds like a plan, cheers!
    And okay cool, I’ll order a couple of them Vex things today! Give them a go as well!
    Bad Wolf
