been a while since i have done anything to this so i thought id bring everyone up to speed
since i last played with anything work descended on my life like the proverbial ton of bricks and i lost a bit of time i then suddenly i had entered a competition and had nothing to fight with so i panicky turned to harry and with his help..and me throwing money at him till i was poor the creature you see in the picture below was created amazingly it all came in weight even with 4 mm steel wedge and bumpers
bone-crusher mk2
iron games scotland:
being my first competition i was decidedly unsure how it was going to go but thankfully everyone was accepting of my nervousness the night before after a simple rewiring screw up i fried the entire wiring set up thankfully the link melted before any damage was done but it did mean that i was going into my first competition having never even tested the thing they let me chuck it in the box for a bit between pay to play fights and i discovered 2 very important things 1. allways check you have tightened the grub screws on your hubs 2. it doesn't handle like anything i have ever driven before...great but i was positive my wedge of doom was ready for anything......
fight 1 eggbeater:
i was nervous and i was drawn against the one bot i was worried about at the comp simply because it was a vertical spinner that i was convinced was going to rip my front wedge clean off thankfully he was having as many issues as i was he couldn't spin up and drive at the same time or at least not very well so my plan was to avoid the front and shove him side on and pit him activate calls out and i charge...and immediately turn left i take it a bit more gentle this time and get proper forward movement however i drive straight into the nasty spinning bar of unpleasantness amazingly the front stays solid on the bot and it does a double back flip and carry's on moving then his bar stops moving so i figure this is my chance i charge in and wedge myself in under the blade stopping hit from spinning however as i try to push him i find myself going backwards making a nasty grinding noise which turned out to be the hubs that had come loose from the motor shafts after some more pushing and some more back flips cease was called and egg beater got it on a judges decision i felt better knowing i could take a pounding but i definitely need to sharpen the wedge so that it gets under people.
fight 2 flatulance:
having tightened the grub screws i was determined to do better however my next fight was against flatulence who after much dancing between us both lifted me up and beached me on my rear bumper the fight was pretty uneventful and once again i had the wonderful noise of hubs spinning on wheels meaning i have no pushing power at all
fight 3 fqhwaghds:
this was more of a dignity saver attempt for me having won nothing so far and surely i couldn't lose to a bunch of cable ties and optimism...oh how wrong was i things started off well i was able to push him about and generally do something i opened the pit thinking i could navigate him round and in my haste to get back into the fight i forgot what my bot does if you give it full throttle...and turned myself directly into the pit
overall it was a good competition and i learnt a great deal including the wonders of loctite and that i need to practice driving this thing watch this space as i will hopefully have the designs up for the mk3 and who knows it might do better than all loses.
suvv
