Were we supposed to get a confirmation email beyond the paypal receipt for the entry fees?
Once you go through paypal you click return to Robo Challenge and select your machine. I have you down but what email address did you use for paypal?
I did that, but my browser was being funny so not sure if it went through alright! And my email I used was FlagCaptured (at) live.co.uk
I'll go check my emails again, see if there's anything that's ended up in the wrong folder haha
Ive got it all ok.
I might have cocked that one up too.
Also, overhead bar. Do you need the link in the shaft (above the bar) again or am I allowed to have it in the body where it can be mounted better and not be so vulnerable. I got some feeling that I would be okay to do this but best check with the EO first. Can send pictures of stuff if needs be.
Thanks.
If your bars spinning and you cant stop it would you be able to safely reach for the link?
Would you remove it even if its sticking out the top if the bar is at full speed? Probably not.
This has been discussed several times with no real conclusion. Stick it in the shaft Harry, and just bend the case of your link slightly so it still goes in but there is a lot more friction. A good pull will get it out but having it fallout would be a remote possibility.
So much innuendo![]()
