Page 41 of 46 FirstFirst ... 313940414243 ... LastLast
Results 401 to 410 of 459
Thread: Team Coolspeedbot: first feather weight robot
  1. #401
    Looks like a neat lifter system, what is the MOD on the gears?
    As far as working to the limits, I try to think of it like this - if I don't test my robot at the extremes of its operation, it is more likely to break in the arena when I really need it to work. If something breaks now, it isn't as big of a deal because it is in a controlled environment and you'll know about it, either to adapt around that limitation or make it more reliable for when you really need it.
    BW: Shu!, The Honey Badger
  2. #402
    Thanks, the gears are MOD 1.
    I think I need to reword what I mean by pushing it cause I'm going to give it some proper test like how much can it easily handle. But I'm more referring to still being in the mindset of being gentle with it, like treating it as the most fragile thing. It can handle it cause rewatching the test I've not tried to force the weapon to move more than it physically can do. i.e. keep the motor spinning after it's fully closed cause my mind keeps tricking me into thinking the gearbox bears are made of paper and will strip their teeth if the motor is spinning for a nanosecond after the weapon is fully open and closed.
  3. #403
  4. #404
    Quote Originally Posted by TeamKnightshade View Post
    Looking really awesome so far, it will be interesting to see how much it can lift/push.
    Thanks, should get a rough idea at some point when I give that a test.
  5. #405
    Sometime later, we have reached the final push. And with the robot near completion weighing 13.35kg. Here is CSB 2. Just need to do little jobs before the blue and black paint job.
  6. #406
    Looks very neat, well done. Looking forwards to seeing it in the arena.
  7. #407
  8. #408
    Thanks, can't wait to get into the arena in just over three weeks.
  9. #409
  10. #410
    Thanks.
