My lipo charger uses a PC power supply to power it. As long as the voltage rating for the power supply matches up with the chargers you should be fine.
I've never had any issues with it. To be honest when they check charging equipment they're usually more interested in checking you have an adequate lipo bag. Even if hypothetically they did have an issue I'm sure they won't stop you competing at the event, just stop you from using the charger. If you can't use the charger at Cheltenham you're welcome to borrow mine since I'll be there too.![]()
