Results 1 to 10 of 29
Thread: Wheels for a cordless drill gear motor | Any suggestions?
Hybrid View
    It would be a 3/8 Unc, and the brass nut thing would be called a brass coupling nut. Normally they are sink plated steel in their common form.
    I made some easily on the lathe if you have access?
    Quote Originally Posted by Roboteernat View Post
    Thanks a lot :-)
    Unfortunately I don't think I know anyone with a lathe. Do you think it might be a good idea to order one made to the right size? Or is there places where you can rent the equipment?
    Thanks again!
    Will
    Quote Originally Posted by willcaddy View Post
    Thanks a lot :-)
    Thanks again!
    Will
    If you are able to, you could become a member of a local Hackspace or Makerspace where you will find like minded people and tools to help out.
    Which wheels did you go for? I could make some and sell them to you for you to insert?
    Renting equipment wouldn't be suitable for a lathe, and even the smaller ones from machinemart etc wouldn't be up for the job, although could do it at a push.
Tags for this Thread
