Results 11 to 20 of 28
Thread: Heavyweight removable link
  1. #11
    *four* links?
  2. #12
    Quote Originally Posted by joey_picus View Post
    *four* links?
    One per motor: for safety, trouble shooting and making sure we don't burn any connectors out.
  3. #13
    Quote Originally Posted by Eventorizon View Post
    Fair enough, I'll stick with the traditional one I think!
  4. #14
    Oh yeah, I missed one... SIZE! We can't fit a 150A Anderson in the robot so we had to go for multiple smaller ones
  5. #15
    I have seen too many self removing Anderson links in the 15 years I'm a roboteer.
    Since we went to EC5 for Bullfrog, we didn't suffer from that anymore.
  6. #16
    Lee's Avatar
    Member
    I have used a 2 pin plug and socket, on the socket my positive is wired into - and out from
    + and I have joined the pins in the plug. The plug has no fuse and therefore no rating, will this be allowed?
  7. #17
    Do you mean a mains power plug? They are not rated for the high currents in a heavyweight and it will likely melt.
  8. #18
    EC8's are fine.. but how you mount them is more important. If you just have an access hole with no cover/ no physical stop to prevent the connector coming out... it probably will.
  9. #19
    R9000's Avatar
    Roboteer
    What's the 'done' way to keep an access cover closed?
  10. #20
    Wingnut
Tags for this Thread
