Not totally overthinking it just don't like the thought of handling a live 150A connector and if I can have a low voltage low current link then I can use a military connector that isn't succeptible to vibration or shock
Thanks for the replys, i read the rules and have them as my bible for creating my machine, but again there is nothing in there to state that custom devices can't be used, which was the main point of asking for clarification on using a custom part.
in regards to damage to the link, first off it would be built in using tough materials i'm experimenting with the use of 3D printed nylon so it should be a strong unit for the purpose, but i'm also looking into molding's ( something that i do regularly) so there is no reason for it to fail providing it can be mounted in a way to reduce damage.
However damage can occur even in the most unlikely of places regardless of planning but with all machines of doom carrying spares is somewhat of a necessity and i see no reason not to carry 2 or 3 spare parts of the link, which again the way its designed allows for it to be unscrewed/bolted and replaces in only a few minuets (whats 4 retaining screws and 2 contact screws really?)
Again i was looking to do something different keeping the unit contained and more professional looking without causing issues with the tech check.
I know none of you know me or my work in other hobbies but if you did you would understand that my work i treat as art as well as functionality so if it looks just hashed together it get scrubbed and i find something better.
Please keep suggestions coming, input is always welcome.
