Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: First time building a flipper robot
  1. #31
    My approach would be t make it 4WD by running some timing belts to the front. That will solve your steering issues and it wont add that much weight to the set up.
  2. #32
    Agreed with Alex, coming from experience never put the wheels at the back unless you have crazy powerful drive like S900s or something, or it'll have horrible steering and won't ever go in a straight line.
  3. #33
    Wheels at the back will give you straight line, but difficult to turn, wheels at the front will give you quick turns, but impossible to go in a straight line.
  4. #34
    Quote Originally Posted by blazerbotics View Post
    Wheels at the back help you go in a straight line? - Great i have to think of an excuse for my driving now :P
  5. #35
    chuck has wheels at the back and goes dead straight, he also can steer ok propably because he has astro motors (very powerful) , is very quick aswell, same setup as jarvis will have soon, pics on another thread.
  6. #36
    Actually Terry Chuck runs an odd combo of Astroflight 940s and T-Boxes that came from Flow originally. They're at a higher ratio of 11.52:1 and are meant for Titan 550 motors. Flow will soon run Astroflight 940s and TWA40s, which are made for the astros and have a 7.78:1 ratio.
  7. #37
    Quote Originally Posted by Danny B View Post
    I've placed an order for a Trev reg, I should be getting it at the Barnsley event. I do already have a 5/2 spring return valve, but I can easily turn it into a 3/2 if I plug one of the outlet ports.
    As for the 8mm hose, would this be a reasonable choice? http://www.indequip.co.uk/catalogue/...b-a22100cdc83c
    Nope; that hose is to large and heavy for what you need.
    This is what most people use. or brand, or chinese knock off, both do fine
    http://www.festo.com/cms/nl-be_be/9718.htm
  8. #38
    So basically, polyurethane is the way to go?
  9. #39
    It can be nylon too, it all depends on manufactorer. It's standard pneumatics stuff.
  10. #40
    Quote Originally Posted by Garfie489 View Post
    It really does. Sorry.
