EPSILON
There had been a period of about where Epsilon's diagnostic systems had been giving nonsensical readings, it would seem it's power core had interacted strangely with something causing some sort of weird suspension in an energy field, moving at a fraction of the rate he should have been moving. Early on he had detected ten other beings pass by him in this strange place, however they were swiftly gone. But now eventually the energy has ebbed away, and suddenly Epsilon finds itself spat out into the normal world again.
Strangely he appears to have knocked a Giant Penguin out on impact, causing it to drop both the knife and leash of the chimera it was holding. Nearby, there are a bunch of very varied beings singing.
TWITCH
As Twitch flies through the control tower, he manages to do it successfully without being spotted. However, this on closer observation isn't as impressive a feat as it may seem - the intricate writing that covers the golem is apparently its magical "programming", but the fact it doesn't seem interested in anything beyond its work station gives the pretty clear impression that it is literally programmed to work there, it doesn't react to anything that isn't on that screen.
He also spots a large red button labelled "Emergency Hangar Door".
