Results 1 to 6 of 6
Thread: What resistor for an unknown LED?
    I want to run an led on 18v for power indication but I don't know the led specs.
    Can anyone give me a rough idea of the resistance needed?
    Thanks
    I use this tool:
    http://led.linear1.org/1led.wiz
    It has info on what stats common colours carry.
    Thanks, I put some average specs in and it said 820ohm, so I've got 4x 200ohm that I had lying around and it seems to be ok.
    Sounds about right.
    Could always just measure the led resistance with a multimeter
    I can do that easy enough and it would make it easier for unknown LEDs, how can I work out the required resistor from that though is there a formula?
