Results 1 to 10 of 67
Thread: Torrent's build diary - a dream coming true!
Hybrid View
    Quote Originally Posted by MudnuK View Post
    What are the effects of having one motor + wheel in front of the other (as in MoBot)?
    You get a good balance between the characteristics of 2WD and 4WD.
    Conventional 2WD with the wheels/motors in line with each other is a very agile setup, but sometimes when driving in straight lines, your robot can have a tendency to veer off to one side or the other (multiple reasons, such as offset weight distribution, one motor turning faster/slower than the other, part of the chassis dragging on the surface).
    Standard 4WD is good at going in straight lines as there are four wheels in contact with the ground which adds resistance, helping to prevent your robot from veering off. The drawback is that when you do try to turn the robot, that resistance is still there, so it doesn't turn as quickly as a 2WD machine (not that you really notice, plus having extra driving force reduces the effect).
    By running diagonal 2WD, you've still got a bit of resistance to veering off because of the offset nature of the wheels, but without the expense of doubling up your motors and/or uprating your speed controller. You lose a bit of manoeuverability, again because of the increased resistance, but as before it's not something you're really aware of.
Tags for this Thread
