But your not allowed to heat your pneumatic system, I think that would count as a heat boaster.
The only thing you can do is put heatsinks on co2 bottles or pipes to help disipate the coldness or perhaps 'accidentally' run you pipes near the motors.
Or run the cold pipes round the motors in order to cool the motors![]()
I don't think anyone would mind, if there were no actual boost to the system, other than keep it running at above freezing
Anway, looks like my lubricator would be ok then. At the moment, my mad experiment uses an onboard compressor (several in the final design, but just playing with one, for now) and these are what need lubricating. Currently trying a scroll compressor which normally compresses freon, not air. Hence the need for added lube.
Edit: Beat me to it, maddox
