Hi Gary
Your quote
"Here's a true walker!" So we can deduce that for you, a true walker is one that doesn't work! I'm joking naturally.
I think we have made some progress. My aim is to have a set of clear tests that confirm the Walker badge under the FRA build rules
I am looking for the minimum (for simplicity's sake) to satisfy the criteria set out in the current rules.
1/ It is supported only on it's legs during its walking or turning phase.
2/ Two degrees of movement must be proved, possibly by showing the gait can be adjusted on a leg Step height or length if necessary.
3/ can anyone think of other tests relating to the rules only, not what you think should be their.
