Page 45 of 55 FirstFirst ... 354344454647 ... LastLast
Results 441 to 450 of 544
Thread: Robo Challenge - 2013 FRA UK Featherweight Championships!
  1. #441
  2. #442
    Massacre's looking good Harry. If you're still having problems with the weapon I'm sure between us all we'll be able to get it up and running. Will be much more fun if we're all spinning in Q1
    Are you around tomorrow or just turning up on Saturday?
    EDIT: The battles should start around 10am
  3. #443
  4. #444
    That all sounds fine to me, can't see anything major missing.
  5. #445
    A packed lunch? You can't send the robot into its first battle without a packed lunch!
    Don't forget the Frubes and cheese strings
  6. #446
    Hey guys
    I need a room. Where I was going to stay has had a problem so I have nowhere to stay tonight. Can anyone help ?
  7. #447
    Good luck to everyone at the Champs, I'll be there next year!
  8. #448
    Any chance of some updates between the qualifying sessions; who has won, who is looking good, highlights?
    Binky is now ready, just giving the batteries a charge, fitted with its new 1.2mm Ti5 ground scraping blade.
    Conker II is almost repaired after yesterdays accident.
    Just beginning to gather the tools together and find boxes to put the robots in, which is hard as both of them are over 500mm wide and 350mm long!
  9. #449
  10. #450
