Results 1 to 7 of 7
Thread: Electric scooter conversion
Hybrid View
    Not exactly a robot but I've recently completed an electric scooter conversion/rebuild. Essentially I started off with a broken one of these off ebay:
    It's a small children's scooter with a 24v 100W motor and 4200mAh of lead acid batteries. Designed for maximum 10mph (presumably if you weigh as much as a small child)
    After a few modifications it looks like:
    I've
    - Replaced drive motor with a hefty Litton (a motor rated '800 watts at 40 amps for 10 mins')
    - Rewelded rear shaft assembly to fit larger wheel
    - Drive changed to 5mm HTD timing pulley/belt
    - Batteries changed to 22.2v 15600mAh Li-Po
    - Controller changed to 4QD Uni 8 (with regenerative braking and acceleration ramping - which you need!)
    - Plus a few other minor things
    Theoretical top speed now 17mph with slightly insane acceleration, video coming soon
    (yes the motor looks silly sticking out the side)
    I'm afraid not, kept on forgetting to get one during the three months it was operational, I remember being far too busy having fun riding it (and nearly killing friends when they tried it without knowing how to use the twist grip accelerator..).
    It's been in bits in the workshop waiting for an aluminium frame re-build for the last two years, I might get around to doing that by Christmas if I'm lucky!
