I'm going to sell my fleaweight in order to fund a second pneumatic ant project:
only competed at the last AWS/FWS so isn't too beaten up appart from a bite in the flipper.
-3D printed nylon chassis
-2x turnigy 14g micro servos speedhacked with a case modification, as usual speedhacked servos are prone to coming unglued if you run them hard or for a long time but they are easy enough to reglue. all metal gears. quite nippy even on the 14mm rubber tyres.
-1x turnigy 14g all metal geared servo for the flipper, activated through a linkage.
-2 cell 7.4v lipo, 130mah high discharge (25c) turnigy nano tech.
-orange 2.4ghz reciever all the connections are soldered direct to the board. this will require your own 2.4ghz dsm2 transmitter. I can solder in a bind plug if somebody would prefer.
-There is a voltage regulator in the back to run the robot on 6v.
It currently has a quick polycarb skirt that I put on for the aws as I didn't have time to mount the carbon fibre Piece I made. I will include the carbon fibre moulded armour if anybody wants to have a go at fitting it.
It currently weighs 65.8g with the polycarb skirt.
this isn't a toy it was built to compete so anybody looking to purchase this to run around for hours on end this isn't suitable, it should be run for 5 minutes max to save burning out drive and over discharging the lipo.
any questions please ask, open to offers send me an email: josh.valman@hotmail.co.uk
The carbonfibre can be seen just placed around the robot here on the right: please note it cureently does not have any way of mounting it and this would have to be developed with some brackets or glue if you really must.
