Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Gears
    I'm looking for gears that are the same as DB5 used. My robot is similar in design, I know there's gears in Technobots but I don't have a clue what to go for. The motor I'm using is Speed 900's.
    The wheels.
    what gear ratio are you looking for?
    If I knew that then I won't be asking.
    So what exactly are you looking for? A gear ratio? What MOD of gears to go for? Your initial question is quite vague. It wouldn't be hard for someone to assume you already know what ratio you're using based on what little information you've provided.
    If it's a ratio you want to know, work out what you want to aim for in terms of top speed of your robot, then use the statistics of your drive motors to work out how fast they'll be spinning at the voltage you intend on running them at. Apply a bit of basic mathematics to calculate how much of a ratio you'll need to drop the speed of the motor to a suitable speed at the wheel. Then decide on what number of teeth your gears will need and take it from there.
    8:1 2 stage sound good.
    It really depends how big wheels you're planning on using. I've gone for single stage 4.5:1 reduction with 75mm wheels
