Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: co2 tank
  1. #11
    A beetleweight. :shock:
    I attempted an antweight FP setup, untill I reread the rules, and found out it was 7 bar limited.
    But a Beetleweight, that's a real challenge. I think the lightest solenoid valve capable of FP I have is 200 grams. And that has a CV of a constipated shrews bowel.
  2. #12
  3. #13
    i have found a lighter solonoid valve:
    http://www.solenoidvalvesuk.com/catalog ... 202010.pdf
    is it useable?
    and i have found some lighter tanks:
    are these useable for full presure co2? thanks
  4. #14
    Max's Avatar
    Member
    You've put the same link twice, you haven't put the link to the co2 tank.
  5. #15
    Quote Originally Posted by Bodge Job
    is it useable?
    Looks exactly like mine. So I guess the 1/8 BSP variant is usable.
  6. #16
  7. #17
    Got one of those, but without a valve.
  8. #18
    i have just found this tank:
    http://www.rap4uk.com/product-p/9313.htm
    considering this have a on/off valve built in, im guessing it would be lighter, more compact, and is less lightly to go wrong? thanks
  9. #19
  10. #20
    If I see the picture, that thip piping is 15mm outside as best. Means 12mm inside.
    length 300mm. Means volume 3,4 cc. Not much of a buffer.
