Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: wiring help for my feather
    everything is there that should be there. I would advise just joining the led to the two main power terminals and if you are using the electronize with a bec, to use that rather than a separate receiver battery but apart from that, it looks fine to me.
    Currently your LED is just attached to the + side of the bat, no complete circuit, so do what Gary says.
    If your using a normal LED use this calculator to figure out what resistor you need;
    http://led.linear1.org/1led.wiz
    LED's with a voltage rating will already have a resistor built in though.
    If you using screw terminals to connect wires be warned the screws will come lose after EVERY bout. So be prepared to tighten them up a lot!
    To get round this you can glue them, but I solder the wires together within the block and then just use the block as a mounting point and insulator.
    Another neat solution is to use o-ring connectors on the end of the leads and then use a nut and bolt to hold them all together. This also has great mounting opportunities (if your robot isn't metal) but can be tricky to insulate.
    On another note, try and keep questions about your robot in your build thread, then you don't have to start loads of new topics, plus it gives people trying to help you an idea of progression.
    In my bots I like to have a main set of terminal points, 1 positive, 1 negative. I have these so that it becomes a lot easier to put new electrical components into the machine. I've used two methods in the past, both with their own merits, to create these terminals.
    The first is a bolt mounted onto a plastic sheet with the bolt head recessed into the plastic. A nut is used to hold the bolt securely in place. The connections are then main using crimped ring connectors of the right size. These are stacked onto the bolt with a second nut securing them in place. I like this method because it has never failed on me (it was the same method used in typhoon 2). The only issue is that you have to find a way to insulate the rest of the bolt and connectors from shorting.
    The second method I used most recently in boner was to use a solid bar of copper (about an inch long, 5mm by 5mm square) and solder all the connections onto this. This method worked well as there is little to no resistance between the connections and it can take huge currents. The problem is that adding or removing connections becomes a pain because I have to use my large soldering iron (100w+) to heat up the layer of solder on the bar.
    To connect batteries or any other removable component I would recommend deans style connectors. Don't bother getting the official ones as they cost a small bomb. You can pick up cheap ones on ebay that do the same job at a fraction of the price.
    cheap deans can also be found on giantcod:
    http://www.giantcod.co.uk/deans-ribbed- ... 05867.html
    And those one's come with a grip!
    ribbed for your combat pleasure
    BEC= Battery Eliminator Circuit.
    An electronical means to reduce the X volt of the main battery to 5-6V and low amperage to power the RX and/or light servo applications you have in your machine.
    For combat robots it has 2 advantages.
    1) No need for 2 batteries
    2) eliminates forgetting to switch off the RX battery
