I would go for one of these http://robotcombat.com/products/0-TD-RCE225.html they will control your motor, and have limit switch inputs so you dont stall/over-run your actuator.
You can do it with servo/microswitches, but i would use them to switch relays to handle the load, you can also fit limit switched into it as well.
