Well, after looking at a few bots on the net and all the new equipment available i've decided to make a bot, 2wd drive with a flipper or lifter, maybe a low pressure flipper system. However I would value anyones opinion of the following:
1.I was thinking of the base plate to be made of 3mm aluminium plate, for which I could attach my mounts and fittings onto.With all the bots being so advanced now will 3mm be enough for the base or am I needing 5 or 6mm?
2. I see that 2.4ghz transmitters are all the go now...has anyone ever used this? type or would you suggest another make or type. I used to own JR and Futaba gear but thats very expensive in 2.4ghz.
http://cgi.ebay.co.uk/Turnigy-9Ch-Trans ... 4cf816b6b2
3. 12V Drill motors and blue wheels seem to the rage at the moment however I think sealed lead bateries are out....what about lipo?s if so anyone suggest a volatge ( I would run 12v motors on 18v with nimhs or nicad but what about lipo's?)
4. Speed controllers from what I remember used to be made out of switches and servos.....but they are a few on the market now anyone suggest a good type to get when using lipo batterys
I value any suggestions or comments
thanks
billy
