feather weight size limit, what is it
there is none
It's exactly how big you can carry * how big the door is.
According to the mentorn rules, and if I recall correctly, any robot between featherweight and superheavyweight has to be between 1.4m*2m in surface size. Height wasn't limited.
Seraph a feather was 850mm wide 1,050mm long and 500mm high. but it is a bit smaller now.in my view the bigger the better
you have to remeber realy the only limit in feather weights is 13.6kg (30lbs) in old money
