Results 1 to 6 of 6
Thread: advice on battery recommendations.
    either nimh or sla should be fine as i doubt the photo frame and leds will draw much current. a high amperage sla or nimh should be more than capable of supplying the amount of power required for 30 mins+. nimhs have the advantage of weighing less and charging faster although are more expensive than sla's. if you have the cash i'd go for nimhs but if you don't want to spend that much and k9 can support the extra weight of sla's and you aren't too fussed about having a charging time of an hour or less then go for sla's.
    I would just put the biggest SLA you can fit in, easiest to charge, as your probably going to need more than 5Ah, in which case your going to end up with multiple NiMh packs, i would just have one SLA.
    I agree with Alan,
    Pilgrim uses 2*12Ah SLA batteries so I can have 24v for speed (series) or 12v for endurance (Parallel).
    If you are using just the lights head movement ETC then you can expect 1 * 12Ah SLA should last a long time.
    If the current load is low they seem to go on discharging close to the 8-12Ah, so 1 amp load 8 hrs use.
    Cheep to buy and easy to charge, when I use Pilgrim I have one set on charge and the other in the robot plus a spare set.
    The only thing I would say is make the battery easy to remove, so swaps are no big deal.
