Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Servo Board
  1. #11
    the receiver he's talking about (planet 5) WILL blow on 7.4v
  2. #12
    http://www.cornwallmodelboats.co.uk/aca ... #aP7710200
    The heavier one seems to be capable of going to 9v.
    Usage I suppose depends on wether the mods to enable the current setup to run a higher voltage weigh more than 0.5 gram.
  3. #13
    Oops, didn't realise they more than 1 planet 5 rx!
  4. #14
  5. #15
    That rating on Spektrum RX's of 3-9v is bull-poo, I've known people blow them up trying to plug a lipo into it.
    When I helped make a 3-Servo lipo ant, I had a voltage regulator that stepped down 7.4v to 6v and powered the receiver, the positive wires from all 3 servos went in before the regulator chip (FET). Spektrum RX's may struggle with that unless you have a large battery and a high rated FET, the one I used was 1.5A.
  6. #16
  7. #17
