hey i hope you don't mind me asking another question but how best to go about making windsreen wipermotor powered lifting forks, nothing fancy just moving them up and back down again.
thanks in advance, harry.
all i can think of it similar to drill motor style and some how attatch some threaded rod on the front and go down that route.
kaizer is a good example, ask ceri for some pics![]()
i think thats over complicating things a bit, cant i just atach the forks straight to the motor some how?
yes, what are the output shafts from the wiper motors like?
You might find it easier using a window motor. No idea what kind of torque/lifting force you'd be able to get but many are a simple rack & pinion based rotating arc which you could attach an arm to, think some feathers have done this before
Here's an example motor http://cgi.ebay.co.uk/Jaguar-Daimler-XJ ... 500wt_1156
or about a fiver from the scrappy![]()
Jamie may hold that against you, Matt. He built Kaizer's lifter not me!Originally Posted by mattsdragons
Though it's a good working mechanism - Kaizer's goes from a drill motor gear box through a welded screw jack designed to lift cars, Laser had a similar mechanism using a drill's existing chuck turning a threaded rod, both suprisingly effective if slower in the task of lifting.
The windscreen wiper or electric window gearboxes or even a seat actuator (SMIDSY used to use some!) would be suitable for use but both the WW motor & Electric window would mount the forks primiarily vertically as opposed to the horizontal plates of Smidsy, Laser & Kaizer n- If they're not strong enough metal wise they will bend!
http://s31.photobucket.com/albums/c3...shirerobotics/
Jamie's photobucket is always good reading - you can see the build of Kaizer's lifter & Rex's robot challenge articles. Good luck!
well your the one who owns it ceri![]()
i had thourght about drill motors, but decided against it, hence why i said windscreend wipers
why?but decided against it
