Results 1 to 10 of 10
Thread: Various valves wanted!
    hi i'm looking for the following valves:
    5/2, 1/8 or 1/4 24v 10 bar solenoid valve
    2/2 atleast 1/224v 10 bar high flowrate solenoid valve
    2x burkert 5404 24v 1/2 valves (or does anyone know where i can buy them?)
    http://shop.ebay.com.au/?_from=R40&_trk ... Categories
    http://www.ebay.com.au/itm/Valve-Soleno ... 56443b8181
    You'd need to get specs on these valve to see if it's suitable for your use.
    thanks for the links woody, i've sent the seller a message asking for a datasheet.
    scratch the 2/2 high flowrate valve from the list above^
    also looking for:
    5/2 valve with high flowrate
    35-45mm bore 75mm-80mm stroke 10 bar ram with rear pivot
    3/2 valve with high flowrate
    still looking for a pneumatic ram of 80mm-100mm stroke, with 40-50mm bore!
    I have 3 rams in the garage 10bar and about 50mm bore 100mm stroke, i will check the size tomorrow and take a pic and post it on here if interested.
  8. #8
    these are the 3 rams i have im sure they are 50mm bore and 100mm stroke.
    I was thinking of £25 each.
  9. #9
    all brackets included aswell.
  10. #10
    thanks terry but i'm really looking for the round cylinder type with a hinge on the back
