what the esc or the battery?
The ESC. I seem to have the same problem you had with the light flashing as if it is in calibration mode when the jumper isn't on.
i found it was i needed a separate rx battery, and that my battery terminaly was a bit loose
Ahh ok, i'm using a separate battery at the moment, it might be a bit dodgy though so i'll check the battery terminals, cheers. I'm guessing you mean the terminal on the ESC?
yes![]()
Great, will give that a try, cheers![]()
sorry for the rather large bump, i didn't think it warrented another thread.
there seems to be a worrying gap between the motors when i push the stick forwards, one seems to start quicker than the other so i end up going in circles, any ideas whats going wrong?
atm im just giving everthing a charge to see if that helps but it tried it with a couple different batteries.
thanks
Have you tried recalibrating the ESC to your transmitter?
