Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Team Orr
  1. #11
  2. #12
    Thanks Fella's, i will probably end up getting those ESC's then. What should i use to control the Weapon motors? I was thinking a simple Bang Bang style switch hooked up to both motors, i dont really need variable control for that, but if anybody else has a idea feel free to throw them out there. Im also in need of some Pulleys/Belts, does anyone know where i can get some for a reasonable price? Thanks again.
  3. #13
    could use 1 of these to turn a 50a car relay on http://www.ebay.co.uk/itm/SOLDERLESS-RC ... 786wt_1270 or a really cheap ESC to activate the relay http://www.giantcod.co.uk/speed-control ... 05435.html
  4. #14
    Escs and relays don't mix well, and that's a brushless esc. Also that rc switch is pretty rubbish, go for a turnigy rc switch.
  5. #15
    oh sorry thought it was a brushed 1 ... didn't really read the description
  6. #16
    to elaborate on my previous point, escs work by turning on and off very quickly. this ends up in the relay welding shut. A turnigy rc switch and a large relay should do fine,
    http://www.ebay.co.uk/itm/RC-Turnigy-Re ... 188wt_1114
  7. #17
    Thanks for the info Jonny.
    Also contrary to my previous statement it appears my parents are prepared to shell out a bit more money after i did so well in my maths GCSE :wink: So my question to you is this: Which reliable ESC should i go for? The cheap Hong Kong ones look tempting but if a Sabertooth or similar is available then that would be better, preferably under or around £60. Anyone got a recommendation/supplier?
    Thanks again
  8. #18
  9. #19
    i'm using 1 of these http://www.technobotsonline.com/saberto ... or-rc.html
    but from other bits on the forum some people have had problems
  10. #20
