how much does an electonize 30a weigh
not enough to matter![]()
what wire gauge do I need if I'm running 2 18v bateries in parrallel
The DC voltage we run doesn't have much to do with the wire gauge, it's the amperes that decide.Originally Posted by gizmo
In the industry , 10 amperes per m² is seen as on the edge.
So, how much amps do you expect to draw?
The batteries say 1.3Ah and I'm using the motors from the same drill
That ain't the information needed for wire gauge either.
It just means that each battery theoreticaly contains 18V*1.3ah= 23.4 watts.
Those probably are very cheap batterydrills?
If so, the batteries can achieve maybe C15, meaning a max of 2 times 19.5A for 3 minutes ,and hopefully survive that. (not the first of those I see go up in smoke and molten plastic)
Meaning you can wire the robot with 4 mm² wire.
which is better as a drive motor, a cheap 18v drill motor at 18v or a £10 argos drill at 18v![]()
Depends on wheelsize and support.
But a cheap drill overvolted, we have seen that before. If the motor doesn't melt, the gears will fail, and if those are replaced with metal gears, the pins will work lose from the planet carriers.
what dimensions are the argos 12v (£12) drill motors? I'm mostly intrested the length of the motor with the gearbox attached.
does a RadioLink R7EH 7 channel receiver (2.4GHz) need a battery or what ether they're called?
