Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 135
Thread: Moving to Lithium
  1. #101
  2. #102
  3. #103
    Quote Originally Posted by mr_turbulence
    And when you drop them the four horse men of the appocolypse escape and hell freezes over....
    in reality lipos seem to be getting bad press of people in the robot circuit from people who in reality know nothing about them...
    Last Sunday on the airfield:
    And nothing bad happened to the lipo.
  4. #104
    Yup, seen them smash into the ground in helis too- no damage... I had one mounted to the front of my brushless combat wing... Nose dived into the ground going about 150mph and it didn't do much.
  5. #105
    This Funjet was doing about the same speed. The lipo is about 80% buried into the ground.
  6. #106
    Oh yeah! I can see just about buried it is now, impressive!
  7. #107
    Max's Avatar
    Member
    Would a battery like this:
    http://www.giantcod.co.uk/3000mah-lipo- ... 06608.html
    Be able to run two Argos drill motors and a speed 900 or simulaly powered axe weapon? And would it need charging in-between fights?
  8. #108
    Going by the spec's it probably would yeah, but I notice that people in this thread often say that Li-Po's vary vastly by brand and with that being GiantCod the brand may be of the cheaper variety.
  9. #109
    Max, check out the 'Gens Ace' range of li-po batteries available on GiantCod. They're still pretty cheap but testing and reports from other users seem to say that their performance is similar to some of the higher-end brands of li-po batteries available. I've got myself a pack for using in Drumroll so will see how they go.
  10. #110
    Max's Avatar
    Member
    So this one would be better
    http://www.giantcod.co.uk/gens-3000-lip ... 06609.html,
    Is a 25c discharge rate going to be enough to power the speed 900 for the axe and the drills?
