Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: V-Tail Mixing
    I've been following the instruction in the manual trying to turn this on on my Spektrum DX6 but it doesn't seem to be working. Anyone know any possible ways I could be going wrong?
    http://manatee-rc.com/Docs/dx6manual-english.pdf
    Page 29 - 30 all about entering system mode.
    Pick Type AC aircraft mode.
    Then
    Delta Wing page 35
    Cheers,
    I was reading through that manual as I had a hard copy in the house too. Not the easiest thing to understand by any means but I think I have it now. It still does some funny things though, for example, everything is controller by the right stick, except turning right which is controller by pressing forward on the left stick, bizarrely. I'm going to try resetting to factory defaults then do as you suggested again.
    Thanks again Woody.
    You just have to plug the different leads from your ESC to different channels and then it's just luck trying to find a combo that works for you
    ahhhh, i see now, my miss understanding
    Thought i'd bring this back up rather than start a new thread.
    Having some trouble with the way my DX6 is mixing, full forward is up and left and reverse is down and right, I think i'm getting closer to the solution of all this mixing but just cant work out this last (hopefully) small problem.
    Would it not only be no mixing if it needed both sticks to carry out all the different ways of moving?
    The setup is as follows:
    Four drill motors:
    Back two controlled by two Electronize units
    Front two controlled by Scorpion XL
    Electronize and Scorpion XL RC wires going into two Y-leads and then into the receiver.
    It works fine with mixing on the Scorpion (except the rear wheels aren't mixed so they run independently) so with the Scorpion set to tank steering (no mixing) it should be possible to turn on mixing in the radio and control all four wheels with one stick.
    So when we set that up, it would drive correctly mixed but the two front wheels would go slower than the two back wheels. Switch it back to tank steering and the front wheels return to their normal speed. I'm not used to DX6s so I'm unfamiliar with the mixer settings; thought it might be a dual rates issue but that shouldn't be affecting the speed of the front motors when all four wheels are going in the same direction
    EDIT: Tony, the way it was set up when I left was no mixing. One side of the drive was on one channel (up/down) and the other side was on another channel (left/right). When it's mixed, it's combining both channels so that up/down moves both sides of the drive instead of just one, same with left/right.
