Power: x2 9.6v 3300 mAh nimh batteries
Drive: 12V argos drill motors on 10cm blue wheels.
Weapon: a set of linear actuator driven claws with that also running off the 2 9.6V batteries
Control: Electronize 15a esc's with 25a fuses
Armour: 8-10mm HDPE top and base & 5mm checkered steel sides
its quite a small bot with it only being 35cm wide and about 25cm long but im just hoping it comes under the weight limit and more importantly, all my electrics sound like it would work?
also, how many fights with my spec do you think ill get out of the batteries?
