yes wheelchair motors work on heavyweights although as some of them are quite slow (7mph) you may need to either use different gearing, bigger wheels or change one of the gearbox gears to one with a lower amount of teeth which is what the pair i've sold to tony have i beleive. the batteries may be useable it depends on there voltage/amperage/weight and if they will leak acid allover the arena if flipped as can happen with non sealed lead acid batteries. for armour i'd strongly suggest investing with hardox armour as it does seem to be the way forward.
i'd consider the cost, time and skill required to build a fully functional heavyweight that won't get trashed in its 1st fight before you commence your build. but don't let me put you offalso if you can get most of the parts for free go for it
