i want to build a ant weight robot and i want to keep it cheap so i was thinking 2 modded 360 servos for drive a receiver and a battrey any help?![]()
yes that would work but dont expect it to win any thingi did that at the start but i have now moved on to bigger and better things.
cheapest servos(good speed bad torque) easy to speed hack
http://www.giantcod.co.uk/towerpro-s...rvo-p-268.html
batterys
http://www.component-shop.co.uk/
i used both for a while
this is a forum which is more for antweigts which may be helpful
http://www.robotwars101.org/phpBB/index.php
do i have to use servos or can i plug a motor in the recever?
a motor needs a speed controler which plugs into the reiver, its is much more expensive but nearly all ants use it. speed contollers are about £45
Servo robot at http://windisch.co.uk/robots/howto/build_a_robot.htm
Motor robot at http://www.antweightrobots.com/kitty/index.htm
You might also want to try http://www.robotwars101.org/phpBB/ for antweight questions.
IVE GOT THE SMALL SERVOS FROM GIANT COD £5 FOR 2
ps not reccommended![]()
whats not recomended?
his cheap servos I think he means
very much recomented by me though
