Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: building speed controller out of solenoids?
    i was thinking about building a cheap bang-bang speed controller today and came across this:
    http://www.ukrobotics.com/html/hints&ti ... ontrol.htm
    has anyone tried this or have any wiring diagrams?
    You wire up the contacts of the solenoids in an h bridge and the coils of the 'diagonal' solenoids together and have a microswich to turn on each coil pair.
    http://www.6x6world.com/forums/conte...ridge.jpg.html
    Pretty similar to that but with two microswitches instead of a switch.
    I'd recommend using solid state relays instead of solenoids.
    http://www.jaycarelectronics.co.uk/prod ... BCATID=754
    These would happily do the job. Mount it to a metal chassis for heat dissipation and these will keep running all day long. Stalled a small mag for 5 seconds or so with one of them. The mag was nackered but the relay was fine.
    thanks for all the reply's i probably won't use bang-bang control. i was just thinking about using it temporarily until i can afford a proper one. but i'll just wait and hope someones able to sell me one used
    Quote Originally Posted by typhoon_driver
    These only close one way, so using them in an bang bang system would short the connection to the battery. Unless you put a hefty diode in front of every SSR. They are very good though, we've used them in our spinners as well.
    The contactor I suggested is a motor controller in itself with forward / stop / reverse all there with two units and 2 servos with micro-switches you have a simple bang bang controller for 2 motors. but I would still recommend a PWM controller.
