Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: need a speed controller
  1. #11
    running 18v would probably be ok but i'd never be happy about pushing a couple of robots around with it ie stressing it
  2. #12
  3. #13
    never used them but many people have very successfully used the scorpion controllers in relatively big current draw applications.
  4. #14
    I used a scorpion XL on a pair of 18v drill motors run on the same voltage, didn't have any problems after numerous fights (including a butt-kicking from Little Hitter) until I moved to spektrum, because the battery eliminator circuit (BEC) was not powerful enough to supply the receiver, so I had to buy a seperate voltage regulator/BEC to supply 1.5A to power my RX, Gyro and switcher
  5. #15
  6. #16
    Me personally, I've seen too many broken sabretooths in the FW's, especially them coming off the heatsink (like calums and Ceri's as I recall), no such issues with the scorpion. There quite a few good machines to use the scorpion, the 3 Big Nipper FW's all use one, 360 uses one, and I believe the Shock team use them.
  7. #17
    they're also alot smaller than the sabretooth
  8. #18
  9. #19
  10. #20
