Results 1 to 8 of 8
Thread: Forward AND Reverse low voltage cut out for Lipo's
    What cut outs do people use on their drive motors. I have a kill switch for my weapon which is mono-directional but I cant find a low voltage cut off which does both directions. What do other people use?
    The electronics in the system is a 4 cell 4Ah Li-po, Electronize ESC's, a IMX-1 invertible mixer and 2 GR01 motors.
    low voltage for both directions?!?!? I don't understand.
    Voltage is merely an electrical potential between two points and your voltage cut off will be sitting monitoring the battery. When the potential drops below a certain value, it cuts out. Direction has nothing to do with it as your machine should be setup for positive and negative to be wired up correctly to the cut off.
    I don't bother with a cut off and instead just over spec the size of the lipo pack. Main bonus doing this is that I get far higher discharge rates (easily up to 150A plus) from a large pack.
    All of the Li-po cut offs have this bit of text at the bottom in some form or another...
    CellShield is intended for aircraft with 0-100% style one direction only throttle. A future product will be aimed at cars. -http://www.technobotsonline.com/cell...r /> <br /> If
    Quote Originally Posted by Eventorizon
    All I am worried about not is cell inbalance and under-volting the cells to a dangerous level.
    http://www.giantcod.co.uk/battery-teste ... 06197.html
    There are worse ways to spend £3. It's not a cut-off but will help keep an eye on cell balance and low voltage. Like you said though, shouldn't be much of an issue as your lipo is over-spec'd.
    Interesting. I'll admit i never bothered looking at the details of lipo cut offs. I always just assumed they worked completely on the power side of things and never bothered the radio signal.
    What a farce!
    I'm all for just overspec your Li-Po.
    The round is only 3 minutes, so just make sure you won't drain it in that time.
    You should be balancing the pack after every round anyway (it's a good idea to check it for damage too).
    And if you've fused appropriately then that should protect you against any excessive discharge, say from a short or burnt out motor.
