You would know pretty quick if you put 20volts through a receiver, the smoke would be rather evident. Unless you have managed to change the wiring then your BECs will be wired up in parallel, ie all positive lines connected together and all negative ones connected together. This means the voltage the receiver sees is the same but there is more current available. Check out some basic circuit theory on google (parallel and series circuits).
The power to the receiver doesn't affect the response of the speed controllers. It is the signal line (the white one) that comes out of the speed controller. Look on google at servo control (pulse width modulation) and you'll learn how the receiver communicates with the speed controller.
What speed controllers are you using?
