Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: wheels and motors help needed!
    today i mounted my rear wheels but when i went to test it, i herd the motors turning but the wheels were not moving.
    it could be a few things:
    batteries not fully charged
    motors cant handle the weight (9KG at the moment)
    friction caused by the front on the ground (i am mounting front wheels, i wanted to test the rear ones though)
    the motors are 12V so they should be able to handle it, the front wheels are being mounted next weekend and the batteries will be fully charged.
    any thing else i can do?
    i presume your using drill motors, and the problem suggests you have locked the gear box with grub screws
    if you are using drills, when you took them apart there would have been loads of little ball bearing falling everywhere down the holes they came from you need to put a grub screw to do the same job as the ball bearings
    hope this helps
    anyone else?
    well are you using drills or not?
    sounds like you havnt hacked your drill motor- if thats what your using, otherwise your motor will spin but not transfer any drive to the output shaft.......
    A little more information is required about your setup before any sensible advice can be given.
    What motors are you using (drills or something else)?
    What batteries?
    What radio gear?
    What speed controllers?
    Working out problems with robots should be done by isolating each part of the system, checking it out as far as possible and eliminating it from the overall problem.
    I'd also advise that the comment you made anyone else? without any further information about what you had and hadn't checked from the post that Alex made comes across as rather rude. One of the tricky things about communicating on the net is making sure that you come across in the correct way when asking for advice.
    Quote Originally Posted by typhoon_driver
    What motors are you using (drills or something else)? drill motors
    What batteries? the batteries from the drills atm
    What radio gear? none atm, did a dry run with the drill push switch to check the motors
    What speed controllers? none atm, look above
    answered above. i see what your saying, communication via web is hard and im sorry if i came across as rude.
    i did a test with the wheels with no weight on them and they worked fine. i am adding front wheels next weekend to reduce friction, and charge the batteries fully then ill try again
    No bother, we're all here to help each other out
