Hi it's me
I decided to make a robot diary because my robot has started to take place like the base of the frame is doneand the rest of the frame has started
I will try to put pics up and update this!!!!!!!
Theo
Hi it's me
Theo
i have a pic ready !!!!!!!!!!!!!!!!
and it is not that good and is not milled alilol
and i cant put it on this website =( so...
i mite make a robot team webpage but what should be my team name!!!!!!!!!!!!!!!!
Easier option for images. Get a photobucket, or use imageshack.us then copy and paste the url which starts with [img] here
got the picture problemo fixed and sosorry for it being small)
as i said on my pneumatic topic
i have a cylinder on its way, brougt it of ebay.
its 16 bore and 54 stroke double acting brand new (so they say!)
will get abit done on the frame this half term so more pics on your way
I've already said in the pneumatics thread it's 40mm stroke.
The seller isn't consistent in the strokes length...
NEW SMC PNEUMATIC CYLINDER
CDQSB16-40DC
MAX 1 Mpa (145 psi)
4 MM ID FEED HOLES
16 MM BORE
50 MM STROKE
72 X 29 X 29 MM
AND
PNEUMATIC CYL-SMC-CDQSB16-40DC
BORE16-STROKE 54MM-NEW wrong!
The 40 in the part number is the stroke length.
thats still ok stroke for my robot!
If your happy that's fine![]()
yes i am happy should be here any time soooooooooon!!!!!!!!!!
if u want arc welding rods go to 'tool station'
me and my dad got 300 steel weldingrods for a £5-er![]()
and here is a bit of an inprovement on the frame!(and the rods!)
just got home and the cylinder has come!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
its inline with my ipod touch and its 5 inches long when its fired and the stroke is 40mm, and is 3 cm wide and the bore is 16mm
i am running it at 144 psi/10 bars and working pressure max is 145psi and max pressure is 160 psi
