i'm still on the lookout for a regulator myself![]()
its so hard to find good regulator that r cheap isnt it! (HINT,HINT :wink: :wink: robo challenge!)
I'd assume that it's probably one designed for use with a welder similar to these here,I got a Co2/Argon regulator 60 bar inlet 10 bar outlet
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
has anyone used 10 bars on a valve with a working bars at max 8?
Yes ...
Should you.... NO the manufacturers max should be observed.
just got home and the cylinder has come!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
its inline with my ipod touch and its 5 inches long when its fired and the stroke is 40mm, and is 3 cm wide and the bore is 16mm
i am running it at 144 psi/10 bars and working pressure max is 145psi and max pressure is 160 psi
Im not having a dig but isnt that a little on the small side :/
Did you use the Calculators people suggested?
Ive calculated that above flipper tip you'll get an air time of 0.02 meters
its pretty small so mite sell it one ebay ad get a bigger one and its descripsion was so wrong![]()
you could ask for a refund dew to misleading description.
Hopfully he or she doesn't read this!!!!!!!!
But good idea
