good!
good!
so this is 1/8 but 1/4 will fit it
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
Theo
Theo ...
These sort of questions arises ALL the time in the early build of newbies.
The problem is your lack of understanding and the difficulty in transfering knowledge 2 you via this medium.
So I'll try once again.
I connect pneumatic ports together with nylon/plastic tube.
The nylon tube pushes into a fitting that is screwed into the port/s of the various components.
These fittings are available with many combinations of threads and push in tube sizes.
http://www.accltd.com/main.asp?category ... 4wodfF7aMA
I'd recommend 6mm nylon tube.
So your push fittings will be 1/8 bsp thread + 6mm tube for the ebay cylinder and 1/4 bsp thread + 6mm tube for the ebay valve.
Everything will then be connected together with 6mm tube.
... re=related
So ...You'll want fittings that suit your port thread size and nylon tube size.
Pic shows 1/8 bsp + 6mm push fit into cylinder then 6mm tube into a 1/4 bsp push fit.
AAA Battery in pic for scale.[attachment=0:37v7qes0]fittingss.jpg[/attachment:37v7qes0]
Have a browse thru some of these ....
Thx for the vid and pic
Just wondering would 150psi and 1meter of pipe and a cylinder of 16mm bore and 54mm stroke and no buffer tank be able to 'flip' a robot IN THE AIR?
How's your math?
So .... Lets take your cylinder 16mm bore and 54mm stroke @ 10 bar.
Force = .008 x 16 x 16 x 10 = 20.48 kgf
So you could potentially move a mass of 20.48 kg's a distance of 54mm OR
1/2 the mass twice the distance.... 10.24 Kg's a distance of 108mm.
You could possibly self right yourself or turn someone over with such a low force
NO AIR TIME.
NOTE:-
If your flipper tip lift to cylinder stroke ratio is 2 .... i.e. 108mm of flipper tip movement ...then you'll only be able to lift 10.24 kg's.
What you need is to maximise these two equations.
Energy = Pressure x Volume
AND
Power = Energy / Time
OR as much pressure as possible/practical in the biggest cylinder possible/practical and this ENERGY applied / delivered in the shortest possible time.
The time part of the equation is gas supply or flow dependant ...
Ok then thank for the help
and I am the best in my school in maths! No joke!
Proberly get it up and running(some events and prob a buffer tank if got space in robot) then update parts in about a year or later or sooner! To 750 psi :shock:
on the plus got my cylinder on it's way!!!!!!!
Theo
does this:
http://cgi.ebay.co.uk/METALWORK-PNEUMAT ... dZViewItem
fit onto this:
http://www.technobotsonline.com/10-bar- ... 32488.html
just wondering because the valve is G1/4 and the stud is bsp1/4?
it'd be easier to buy a valve with the coil. like this:
http://cgi.ebay.co.uk/5-port-solenoid-v ... 500wt_1156
this valve would work if you are going to be running of 24v. or you could buy one new from:
http://cgi.ebay.co.uk/Pneumatic-Solenoi ... 797wt_1141
i bought a 24v 3/8 valve from this seller. all seems good.
