You do not have to have a plug ....... you do however require a properly insulated connection.
hi
more Q![]()
What would be a good double acting cylinder bore and stroke
(i needs to flip my robot over with about 10 bars)
Theo
The question is a little open ended and vague.
The answer is I'm afraid going to be much the same ...
It all depends on your design...
Example ...how much energy do you need to supply to self right a 13kg Weeble?
How much energy do you need to supply to self right a 13kg wheeled brick?
Right so more detail........
my stroke is going to be small
about 100mm or so
And how big is a 0.600kg CO2 tank/bottle
( length ect)
Theo
Woody wrote the following in a thread over on RoboWars (which I already linked to FYI)...What would be a good double acting cylinder bore and stroke
(i needs to flip my robot over with about 10 bars).
my stroke is going to be small about 100mm or so
Quick and rough calc for guesstimating the potential throw of a ram .
Swept area of cylinder in cubic inches multiplied by the pressure in psi.
Divide this by the weight to be thrown in lb's and then halve the result to account for inefficiency.
So for your 50mm x 40mm we get a swept area of 4.77 cubic inches
multiply that by your pressure 150 psi.
That gives us 715 lb ins .... divide that by the weight to be thrown..... in your case 30lbs .....this gives us nearly 24 inches of potential throw.
Divide that by the inefficiency factor and we get 12 inches of throw.
...so decide how high you want to throw the 'bot and then back-calculate the cylinder bore.
Use this site to convert the different volumes/pressures/etc... http://www.onlineconversion.com/
viewtopic.php?f=111&t=2065&hilit=+bottle+dimension s
Thx for the help
I have the cylinder bore and stroke,
just need a place to get 1.
Been looking on eBay but no luck
so do u know somewhere to get a
double acting cylinder cheeply
Theo
Ask the vendor if he can supply some specs.
http://cgi.ebay.co.uk/Job-Lot-Air-Pneum ... 1c15f589b1
Note 32mm bore is a std size.
Slightly longer stroke.
http://cgi.ebay.co.uk/PARKER-ISO-CETOP- ... 336093360b
i will proberly go with the second 1
(so no one buy 3)
Theo
is there a website that sales clylinders
max about £50
Theo
