Page 4 of 18 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 174
Thread: Hard Time's build diary
  1. #31
  2. #32
    so are you running the other 2 wheels via a belt drive from the motors?? or are they just dead wheels ???
  3. #33
  4. #34
  5. #35
  6. #36
    Ordered bearings and steel bar from technobots last night.
    These are the bearings:
    http://www.technobotsonline.com/miniatu ... x24x6.html
    ...And these are the steel bar: https://www.technobotsonline.com/silver ... 33173.html
    I need a 12v battery that can power 2 drive motors and a lifter motor I'm thinking of using this battery: http://www.technobotsonline.com/haze-hz ... 2.2ah.html
    Is it the right battery? If it is'nt what kind of battery is better?
  7. #37
    That's a sealed lead acid battery. Usable but somewhat under powered. SLAs were used around 4 or 5 years ago in featherweights and were the standard at the time.
    I'd recommend looking at nimh batteries instead. Something like this pack here,
    http://cgi.ebay.co.uk/12V-3700mAh-NiMH- ... 3353ee4e1a
    Will give you all the power you need for your 3 drill motors. I have used these packs in the past and they have been fine.
  8. #38
  9. #39
  10. #40
