Well Aftershock has been around for a while now and the chassis is pretty well ruined after 3 years of service.
So its time for a new one and this time we've gone for a completely new design but using most of the same parts as before hence Aftershock 2.
The new one is much more compact than before, this has allowed for armour which is 3 times thicker than the old one as well as the addition of a much needed buffer tank to improve the flipper.
So here are the stats for Aftershock 2
Weight: Weighed it yesterday- came in at 12.5kg![]()
Length: 40cm
Width: 42cm
Height: 16cm
Drive: 2x 18v drills running 75mm blue wheels
Speedo: Scorpion XL
Batteries: 24v Ni-Mh, 1600mAh
Rx: BR6000
Armour: 14mm HDPE with 8mm Aluminium flipper arm
Weapon: Full pressure flipper with 32mm bore 60mm stroke ram with 9oz paintball bottle buffer tank
Photos can be found here http://s881.photobucket.com/albums/ac13 ... shock%202/
And finally heres a video
That was with very little gas left in the bottle, the buffer seems to have made a fair bit of difference to the flipper power. Still got a couple of things to sort out- but should definately be ready in time for the UK Champs
