While we're on the subject of controllers, how would i control my electric jaw with a planet 5 2.4ghz?
Have the movement on one stick and weapon on the throttle stick.
It does depend on what you are using to control your claw. For example, if its a relay control, you just plug the servo into whichever channel you want to operate the weapon with. Stick up/left = claw goes down, stick down/right = claw goes up, or whichever.
As for speed controllers, I personally like and have used the Scorpion XXL, I would recommend it.
Even I've only managed to blow one of the scorpions which is nothing short of miraculous for a speedo!!Originally Posted by razerdave
I have broken the same one twice :P Well, I say I did, the first time I think it was Hornet, second time it was something I did, but I still don't know what it was.
But when it does work it works very well. If you want an example of how good, Little Hitter and Little Flipper both use one and they're some of the most reliable robots on the circuit.
Not many people have mentioned the sabertooth? does that mean its pants? the figures suggest its the better one? however i like the link that widow_twanky sent me. i have a few Q's though, does the first link do the same job as a esc? i understand it like this. i connect my receiver to that Servo Pulse to Dual H-Bridge Interface this does its magic and sends the signal to my h bridge that controls my motors? if this is correct i think i will go down this root. if the more techy people could give me a hand with which electronics i need to make, i can through the schematics at my dad and he can get the pic programed and get necessary bits and bobs. my dad doesnt really know electronics, hes the CAD guy, but he sits next to the software and the electronics guys at work which would be more than happy to help. they actually make sensing and controlling units for industry. they cant really look into it as it'l be done in works time, so if someone could tell me what exactly i need, they'l get me the bits and do the programming and ill solder it all together
Cheers for all the input.
my honest answer is to keep it all as simple as possible at first. Buy a commercial controller that plugs into the receiver and get a robot chassis running.
Many people over the years have tried and many have failed to develop their own speedos. A few have succeeded. One thing that all had in common was a great expertise in electronic design.
Even with the heavyweight I won robot wars with, typhoon 2 we had some custom electronics in there to help with the disc spin up in the later variations of the machine and those were no easy feat to develop.
I can understand your enthusiasm but you will save time, money and many a heartache on your first machine if you buy a ready made controller, ie plug and play.
The sabretooth is a nice controller but it's rated specs are somewhat high. Personally I have burned a few out using them to their limits with overvolted drill motors.
Ok thanks for the input. maybe i should buy an off the shelf speedo first to get something running and work on my own speedo after. im just worried that im gonna burn the scorpion out. i think im going to use scooter motors for drive. i checked the stall current by actually stalling an old scooter motor ive had for years. i plan to use the same ones in my robot. it drew 20 amps at stall which i thought was very low? what do you think? i just locked the motor shaft with some pliers and put a multimeter in the circuit to give me that figure. if the batteries were partially flat could this effect the reading? i heard someone saying they use scooter motors with the scorpion xll and runs ok. im just worried it wont be able to handle it.
Thanks
It should be fine. If i remember right (and please someone else correct me if im wrong) the scorpion xxl has current limiting on board anyway?
You will struggle to stall a scooter motor in a featherweight due to the torque they produce. You will be more likely to spin the wheels
FANSATIC! and yer i forgot they DO have current limiting. i was also worried that there would be no point using up that weight in scooter motors if they only ran at half power. but your advice coupled with my little experiment and what iv'e read online, im happy to go with the scorpion now. i'll hang on a little and see if someone posts something to change my mind though.
one more thing! do you mind telling me what motors you used for the spin in the featherweight typhoon? i remember that it was very impressive.
Cheerrs Dude you're been a massive help.
