Page 29 of 31 FirstFirst ... 192728293031 LastLast
Results 281 to 290 of 307
Thread: Robo Challenge - Predator
  1. #281
    Cheers Jamie! Lets hope it comes good, would be a good battle 1v1
  2. #282
    Had a harsh draw for the UK championships which sees Predator against 2 nasty spinners. I do have around 2 kg to play with but i may just leave it if the machine does well in testing. I need to beef the front of the chassis up but other than that it may just get some lead in the base to lower the cofg. Yesterday i made an end stop buffer for the head to stop it going to far back and hitting itself. Just need to make a little pic up so we can add limit switches to the head and arms.
    Here comes the champs!
  3. #283
    magnets?
  4. #284
    Not keen on magnets as I havent seen them work well that often. I may try some for testing and see how it goes. Im also rapidly running out of space lol.
  5. #285
    Surprised to find mounting the weapon speedo and links is the biggest challenge of this build!
  6. #286
    Unimportant bits then....
  7. #287
    The links are a real problem... where on earth do you put them on Predator with out being too close to the disc or the arms
  8. #288
    For the last 2 years we've done the links the night before :s It's a serious consideration that people always overlook.
  9. #289
    james I would worry more about keeping it from the disc. I'm sure the arms could hurt if you caught your fingers in there but generally i like to have my link in a location that when I'm working out channels on the tx and it inevitably goes to full throttle without my input i can easily get the link out.
  10. #290
    Top of the tail just below the motor, away from the disk and between the arms,
