Page 9 of 31 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 307
Thread: Robo Challenge - Predator
  1. #81
    Gradually welded to avoid distortion. Worked this time!
  2. #82
    Both shoulders complete and in position
  3. #83
    Second arm bent and ready to be welded
  4. #84
    Arm end plates welded on
  5. #85
    Both arms all welded. Predator looks great from this angle!
  6. #86
    Turning the bearing mount for the head in the lathe
  7. #87
    Bearing hole almost finished
  8. #88
    Bearing plate with part of the cradle attached
  9. #89
    Front of bearing plate drilled and taped ready to be bolted on
  10. #90
    Almost finished with bearing pressed in.
